Most important rule is... make sure you arrived at the right address before your excavator bucket enters the building :whistlingWhat are some rules of thumb for demo work??
Unfortunately with copper prices under $3000 a ton and iron hovering around $100-$150 a ton, its almost not worth it. The copper will make you a little cash, but iron will be hard. That is if you can even find a scrap yard that wants iron right now. There are several large scale projects here complete last year. When the jobs started iron was around $400 a ton. By the time they had the building on the ground, and the iron cut to 2ftx4ft, iron had fallen to $100 a ton. The iron they prepared is still sitting where the building stood. It is likely to sit there for years with the current pricesRecycle as much as you can to help enhance your profits
we made about $1000 each last summer demoing out a small building, they ran 3" copper vent pipes everywhere.Recycle as much as you can to help enhance your profits
that is the best advice ive herd all year... :laughing:Most important rule is... make sure you arrived at the right address before your excavator bucket enters the building :whistling
agreed make $, be safe!Make a profit?
So what are you asking exactly?
I just went through a demo bid and have yet to see any 2 that are even close...the amount of material to remove, number of roll offs, construction of the building, concrete, depth of footings and foundations, utilities, returning site to grade.....on and on.
And my second favorite.... "What's that smell?"by the time someone says what's that noise?? its to late
yeah that one would deffinitley put a damper on the day... i guess you know someone who found that out the hard way...don't loose your thumb by not paying attention to where you cut with the chainsaw.
get it knocked to the ground, deal with the euphorians later.What are some rules of thumb for demo work??
Locate The Water Main, Prior To Starting. :whistling
