1 - 20 of 22 Posts
Controls Guy
It isn't code here but, it should be. I always believe in adding them. I have seen way too many houses around here that are plumbed in only 1/2" copper, you close a faucet and the echo sounds like thunder.
Air chambers will fill with water within 2 months! Waste of time/material!
With city water {100# or so}, install a pressure reducer. Set at 50-60#.
Codes say 80# is MAX, for just that reason. 60# is PLENTY.
Another tidbit... noise is also caused by the burr left by cutting copper pipe! Water swirls inside pipe and w/over 80#, sounds like a train passing thru the house.
If you had # 80 lbs. of pressure that would wear your pipes out prematurely.
Where do you live?
nice looking work:thumbup:
Now show me what this plumbing looks like today.... What? You can't because it's covered up and nobody in history will see it again until they are tearing down the house?
That's what I thought. It's plumbing. If it works correctly and effenciently, then it makes no difference what it looks like. You plumbers really should get stop bragging about the "looks" of your behind-the-wall work. It's not art.
1 - 20 of 22 Posts
