1 - 20 of 22 Posts
Grumpy, I need your advise.
No this is not a seasonal joke. 104 year old Victorian house has a steeple shaped like a witches hat. Inside room is 15' in diameter. Roof line is about 17' from the edge to the peak. I've talked to 10 roofing companys and no one has roofed one of these beasts or has a clue (nor do they want to learn on this one). I can keep the reference lines parallel, but do you cut dimensional shingles into 1/3's, taper each side and lay them like shakes or what? Help!
Existing roof is 3 tab single layer, but it looks like they wrapped a barber's pole and it leaks like a seive.
Crankshaft
Yeah round or square changes the whole dynamic. Round is much harder. I once did a round 10/12 and a box 22/12, or more. IMO 18/12 isn't even a mansard, the box one was damned near straight up.
First throw out your conventional roofing estimating techniques. Your going to need a boom lift to do this one.
If you can post a few pics I can toss you a guesstimate.
I've never actually seen a manufacturer's or other specification on how to do this. What we had done was cut our shingles... a lot of cuts. cut cut cut cut cut
I'd use 2' shingles at the bottom and start my way up. Save the 1' cut offs for the upper mid section. Near the top your going to have to cut even more. The key is to eyeball the correct angle so the shingles butt up against each other and there are no gaps between.
You are right you will be installing the shingles like shakes once you get to the top. Also your lucky that you are using an architectural shingle because it will hide mistakes a little better. :)
I've done 3-4 of these cones. All of mine were shakes, metal or slate, never comp. You can make a wire "ring" at the top, then use a string and a pencil to get even lines around the cone for your courses. Just shorten the string to the next course and mark. I don't think you need the lift. Board the bottom, then board again about 5' up....it looks like you can reach the top then.
Jim
Guys, thanks for the input. This confirms about what I had in mind. Grumpy, the roof deck is OK. The outside is just about finished except for the roof. I'll post pictures as soon as it's done. This has been a $100,000 + rehab job.
Thanks a lot,
Crankshaft
Discussion Starter · #15 ·
Thanks everyone for you input.
It's statring to come together. My crew will start the tear off Monday.
My roofing distributor found a great article in Roofing/Siding/Insulation January 1983 by Harcourt Brace Jovanovich, Inc. This shows how to lay out and cut the angles. My guess was pretty close. Pull two strings from the top to the bottom (36" apart or the width of one shingle at the cone's base). This shows the angle of all cuts. Divide the cone into 3rds (2/3rds shingle and 1/3 shingle and scribe these parallel reference lines around the cone. Start trimming and fill in. Sounds pretty straight forward.
I can save the top cap and reuse it.
Anyone looking for experience to add to their resume?? I'll buy steaks and beer.
Crankshaft
I didn't do this one. The builder told me the peicework labor was 275/sq. There is another one further down the street that has curves and concaves at the valleys and eaves. The cedar shingles were steamed in a homemade steamer overnight and installed the next day wet. 15-20 years old now. Went for $40,000 labor on about 20 sqs. It is also a "freehand" installation on the horizontal. Here are a few more photos. Took 6 months to do. Sorry about the blurred colors, but my photos are way too high a resolution for this board. They are reduced 95% to fit. I'll be over by these jobs in the next few days and will take and post a few fotos of the "steamed" job.
Jim
Crankshaft, that makes sense to me. I was wondering how you would do it with 36" comp. We did it with shakes and slate and just hand trimmed them to mach the angle as we went, but they weren't 36" either.
Grumpy, I agree wholheartedly.
Jim
1 - 20 of 22 Posts
