i have luxaire upflow natural gas furance
which displays diagnostic error code of 5 flashes
this fault indicates if the normally closed contacts in the rollout switch is open . the rollout control is manually rest.if it has opened, chech for proper combustion air, proper inducer opertation, primer heat exchanger failure or burner problem. be sure to rest the switch after correcting the problem the failure?
first where is the loctation of reset switch?
where is rolout switch located to check it
