1 - 20 of 22 Posts
Maker of fine kindling
More info please
How long?
Tapered?
How thick?
ripping round columns
Hey Gus, thanks for the reply. The columns are inch and a quart thick, 8 feet long.not tapered.Just need to make a jig for table saw or circular saw. Thanks.
Official CT Greeter!
could you get a local lumber yard to rip them for ya? I know here our yard will rip stuff down for ya they have da big saws :laughing:
Ripping wood columns
Have to purchase these at Home Depot , no one else have them in stock.There is a time issue and cost a cost issue , so I have to do.I am sure a jig can be made.Thanks
Can you not just attach 8" square blocks on the ends and run them out on a table extention? Or build a solid frame around them and cut them?
I would build a plywood box with 10' sheet goods that the column could slip into.
The top of the box tack a fence for your skill saw so the cut is down the middle.
Get the idea yet?
Cut, rotate, cut.
Obviously you need to register the column correctly both times but I'm sure you can handle that.
I might not cut all the way through both ends so the column keeps shape and finish it off with a hand saw after both cuts are made.
I hope this helps
Get the idea yet?
Cut, rotate, cut.
I hope this helps
That's why Gus makes the big dough!:notworthy
I'd free hand it with the old
Disston 5½ point rip saw, and
cut both sides at once. :cheesygri
Roy Underhill is my friend. :notworthy
You damn old timers!!
On the good side of getting old is all the knowledge and wisdom you acquire.
Unfortunately one of the down sides is that you can gather your scrotum up like a prom dress.
Some good some not so good.
Reactions: Meetre
Glad we didn't attend the same prom. :w00t:
I have done the square block and long table but all the while I am thinking this cut just needs to be clean not straight, they will fit back together regardless...right???
True, but if the saw doesn't track
you remove extra material from the kerf.
Tech Geek
I've done it with a single rip of plywood. Make it the same length and diameter as the column exterior, lay the column on a flat surface, stand the plywood next to the column and screw it to the side of the column.
Measure to the center and adjust your TS fence. Put the plywood against your TS fence and rip the column, then flip the fence to the other side of the blade (same measurement) and rotate the column so the ply is once again sitting on the fence and finish the rip. Done.
Or...snap a chalk line and eyeball it with a circular saw.
1 - 20 of 22 Posts
