I still haven't installed one yet. I'm worried about them braking down. I don't have any parts on my van or even know were to start on those guys. What usually goes wrong with them?They are top of line,thats all i use,most with 20 year manufacturer warranty. Just be sure you know the size you will need for the size of home its going to be installed in,,,ex.# of baths,etc. i always recommend gas units.
Ditto on the Rinnai. Best you can buy. Follow the manufactures directions.:thumbsup:They are top of line,thats all i use,most with 20 year manufacturer warranty. Just be sure you know the size you will need for the size of home its going to be installed in,,,ex.# of baths,etc. i always recommend gas units.
I feel bad for you that times are slow. I hope things get better in jensen beach isn't it?This is personal. Times are slow so I finally get to do some stuff around the house.
The gas co. recommended this brand. I don't have gas so I need a 250 tank in the ground. $3,500 for all. I'm really trying to work out the long term benefits and haven't had time to crunch the numbers.
I also saw someplace that there are problems in low-flow situations without a circulation pump. I know that my pipes aren't insulated. I deal more with getting rid of heat (A/C).
Most of the year there are just two old folks here. Where would my approximate break even year fall? My basic figures come out well after I'm dead. I'm 58.
I had one plumber in house I built about 5 yrs. ago install a system that used a small electric HWT with a recirc pump the idea was for the hot water in the tank absorb the purge while the tank-less unit replenished the small tank.I installed Rinnai in my own home about 3 years ago. The largest btu they had for home use. Two-story house with 4 bathrooms plus kitchen.
Installation requires 3/4 inch cold water supply to unit, plus 1/2 inch hot water to each sink and tub plus 1/2 inch cold to each. No hot water needed to toilets or outside hose bibs. Installation requires 3/4 inch gas line to heater. (If you are installing electric heater, then no vent needed.)
Heater can be placed on outside of house with no vent required, but if gas unit is installed indoors, then you need a proper vent.
Homeowner expectations: Instant hot water, hot service will never turn cold.
Homeowner reality: If you do not install a constant circulation pump, then the system must purge all the cold water in the line before hot water can reach the tub or sink. The time required changes depending on distance from heater, and volume of cold water coming out of the subject faucet.
Without a constant circulation pump, the gas savings are greatest, but the loss of cold water each time the hot line needs to be purged is a wasted resource.
OK, so what happens if you install a constant circulation pump? The heat in the lines is constantly being lost to the surrounding air, so the heater must come on to supply heat to keep the water in the lines hot whether the homeowner is using hot water or not. This use of gas goes on night and day. In my opinion ( I have not tested since I do not have the pump.) the pump ends up using some amount of gas sort of like the old water tank system needed to keep the water hot. The benefit is that there is no need to purge cold water out of the hot water lines. So there is a need to decide whether to pay for extra gas with no waiting time, or to pay for extra water and wait a minute or two for the hot to arrive.
All the following info assumes that there is not a circulating pump installed.
If the hot water at the sink or tub is turned on with a trickle or low flow, the heater will not come on. It will flow cold water until the demand is strong enough to cause the flow sensor in the heater to turn on the heat. The heater needs to sense a strong flow from the hot water faucet to turn itself on. So the homeowner needs to turn the hot on strong and then wait for hot water to arrive.
Taking a shower - this is the biggest cause of frustration. If the hot is too hot, the person is tempted to turn down the hot water demand. Bad idea, because the water heater senses the reduced demand and shuts off the heat. This allows cold water to flow thru the lines until the heat comes back on. So the bather is trying to adjust the water temp while in the shower, and suddenly a minute or so of cold water comes thru the hot water supply. The proper way to adjust for too hot water in the shower is to turn up the cold water, but not to turn down the hot water.
So long as there is constant demand for hot water, the heater will keep supplying hot water. Two or more showers at the same time is no problem for the capacity.
There is a remote water temperature control that allows the homeowner to set the maximum water temperature. I have set mine at 106 degrees. That is not hot enough to scald a person in the shower with only the hot turned on. However it is too hot for comfort, so a little cold is needed to reach a comfortable shower temp.
Maybe the circulation pump would solve the shower problem. Not certain, though.
In three years, I have had no problem with Rinnai and no need for maintenance. That is no guarantee that I will not find a buildup of minerals in the lines. But the function of the equipment has been just fine.
So you're what, a plumber who's an expert at forum triage? :laughing:Too bad this particular part of this forum is beyond help.....Good luck hackers :laughing:
Its good brand,but if the house have a recirculation line use NAVIENSo i have a homeowner who wants to upgrade to a tankless water heater. My plumber wants to use a rinnai which i have never heard of. Any thoughts or comments on tankless (durability etc) and/or the rinnai brand?
