1 - 2 of 2 Posts
Unit is Rheem 3Ph 3 ton has a charge compensator, has equalized pressures 100/100 will not take charge. Has had 3 compressor failures, the first two of which I have no idea as to the nature of the failures. The second compressor was installed by Department of Corrections employees. They attempted to install a used single phase compressor in 3Ph unit. No acid.
Dont want to just start cutting anywhere. Any suggestions
1 - 2 of 2 Posts
