Retrieving a tool after dropping it down blocks
8.6K views 63 replies 23 participants last post by  Joe Fairplay
Due to my paranoia I was wondering if anyone had any ideas on retrieving a tool if it falls in the cinder blocks
#8 ·
Magnet on a rope
Gets to be a pain in the ass with rebar in there. Magnet hangs up on the rebar.
Just don’t leave tools on the top on the block.
And you’re probably not working with cinder block. Haven’t built with it for probably 80 years.
CMUs maybe………
Wow, how old are you?
#30 ·
Idiot straps, like Mom put on my mittens when I was little.
Do i remember correctly that all tools need to be tethered to the workman in Japan if they are working above a certain height? Hence everything has an eyelet to tie to. I remember 20-ish yrs ago when i got my first small japanese cats taw prybar, and there was an eyelet below the head. And the cordless drills came with wrist straps.
#11 ·
I have the fiberglass fish sticks 480 linked.
Besides hanging up on rebar, magnet or no magnet, whatever you are trying to fish out can hang up on the mortar between blocks, which tends to form a downward facing lip. Using a stick let's you position and turn the item so your chances are better.
I take my cue from working in old houses. If you drop it in a wall, leave it there and get another, that's what used to be done.
#15 ·
mainly worried about my hammer falling out of my belt or my keychain breaking off my toolbelt
#29 ·
Don't remember why we were crawling around the insulated attic, but bossman and I were crawling around an insulated attic of a building we were finishing up.
End of day, he goes for his keys, not in his pocket.
Bad enough to be without your keys, but apparently the key chain was custom made by his son using the ivories of his first deer.
Back up we go for another two hours with no success.
Sent from my SM-N960U using Tapatalk
#33 ·
You guys must work in some bad areas if you are taking your keys with you onto a job.
It's only a handful of times a year where I take my keys out and lock the truck up, and I have a zippered pouch on my lunch box where I can place it and keep it in the staging area with the rest of the stuff.
#36 ·
If I'm working alone the keys stay in my pocket, unless I'm crawling around, or carrying an iron tub, or something like that. With the crew, there are two modes of operation:
Upscale neighborhood and we're parked off the street -> keys in cupholder.
Anything else -> keys in a common area inside the building we're working in.
#42 ·
measure to dropped item, demo block cell,
mix mortar, patch.....
install outlet, USB port.....[emoji298][emoji992][emoji1008].
Never set anything of value on CMU wall, that isn't grouted solid......
Cargo pants suck on scaffolding, IMHO
I agree with all of this especially the cargo pants on scaffolding
One time i had to cut a hole in the bottom of the chimney to get my trowel back
