1 - 13 of 13 Posts
Vendor
Can you guys give me a very average idea of how long a respirator filter lasts when you're dry cutting clay or concrete roof tile with a diamond blade? Say that you're doing a moderate to high number of cuts. I called OSHA and 3M and they could only tell me it depends, so I want to hear it from roofers or really anyone who works with particulates and respirators.
Vendor
Discussion Starter · #9 ·
Yeah, I'm just looking for a good approximation so I can determine how many respirators one would use over a period of 25 years, the consensus here seems to be once a day if you're doing a pretty decent amount of work and maybe more often than daily if need be. Does that sound accurate?
Administrator
Sawdust follows Me Everywhere
Respirator or dust mask? If it's a respirator it'll probably never go bad as all you are producing is dust, clean the filter, replace it when you notice it's harder to breath through it. If it's a dusk mask replace them every day.
Accidental Painter
I would think if you smell it when you're wearing it you're breathing the bad stuff. Are you referring to smelling it on the outside of the filters?
Bingo! I have the 3m 6000 series respirator. It has two catridges covered by a cotton filter. The cotton filter is what goes bad first.
So in dusty situations, look at your filters at each break. If it completely covered its shot.
In chemical situations, when the cartridge is bad the fumes are able to pass through.
Another tip: clean shaven is a must to create a good seal. Facial hair WILL create voids around the seal allowing the bad stuff in.
When you put your respirator on cover the cartridges with your hands & breathe in. If you have a proper seal, you should not be able to get air in.
Safety third!
1 - 13 of 13 Posts
