Well i bought a house, tore out the old oil burner and all the ductwork. made up some new ductwork and i'm ready to install it all tomorrow. i'm putting in zone dampers, because, well, i want a zoned system. I have an american standard variable speed furnace, 2 ton cooling. so were looking at about 800 cfm. I've split the house up into the following;
1. office
2. larger bedroom
3. bathroom, kitchen and small bedroom
4. living/dining room.
now my questions. do i need a bypass with a variable speed furnace. the furnace and zone board (Honeywell hz432) both have a terminal to slow down the blower when only 1 zone is calling. if i need a bypass, should i put in a barometric relief type with an arm and a weight, or a motorized with a static pressure control.
typically in commercial (which i mostly work in) you don't see a lot of bypasses with variable speed or freq drives.
1. office
2. larger bedroom
