Hi folks,
I recently replaced a leaky shut-off valve for my toilet. I'm not a licensed plumber, so I'd like to know whether what I did is what an expert would have done. (This was a repair in my own home. Since I'm not a licensed plumber, I don't do plumbing work for my business.)
After removing the compression fitting, the 1.5" stub-out that remained had two compression-ring indentations in the copper pipe. I was planning to install a press-fit, 1/4-turn shut-off valve. I didn't feel comfortable that the fit would be good, given the compression-ring indentations. I cut off the indented portion of the copper stub-out, sweated on a coupler and a new stub-out, cut the stub-out to a more reasonable length, and installed the press-fit shut-off valve. Before attaching the new valve, the stub-out was approx. 3.0"-3.25" (instead of 1.5" as it had been). Everything is leak-proof & working fine, and it has been for a few weeks now.
So here are my questions:
1. Is this what an expert would have done? Or would the press-fit fitting have been just fine if installed over the old indented stub-out? In other words, did I make the repair harder than it needed to be (again!)?
2. Would the repair be up to code? If it matters, I live in the state of WA, in the Seattle metro area.
Thanks!
Steve
Simply Renewed Spaces
Thanks!
Steve
