Hi everyone. I have a client whose house was built in 1980 in western Ohio. It is an all brick ranch on a crawl space. The crawl had no sump or drain tile and no vapor barrier on the ground. He has a very porous brick on the exterior without weep drains. We were called because he had a spot in his subfloor that was buckling. We went into the crawl space and discovered the above mentioned conditions. We have since installed a perimeter tile around the footer, draining it into a new sump pit with pump. We removed all the wet insulation and cleaned the trash out. We also installed a de-humidifier that dumps into the sump so it can run without needing dumped. (The buckled floor has gone down since this was done)
Now to the question at hand. A lot of the mud sills (not pressure treated) are crushed and/or rotting. We were planning on replacing all the mudsill at first but after doing more looking and some test lifts, we feel it may do more damage than good...like cracked drywall, door and window function..etc. We are thinking about taking more of a stabilization approach. We would put tension up on the joists and install pressure treated beams that would be permanently supported down to the footers. Our only concern is the existing sill...what are the cons to leaving it? When it gets warmer we are having the brick sealed to help with exterior moisture and then we are having the crawl space spray foamed and a 12 mil vapor barrier installed. Thanks for the insight!
