gobacktothatfieldandlookforyourenglishteacher
I recently rented a machine my operator had a couple errors bent a outside marker disk n cut a front left tire man are they really hitting me hard with this bill charged me $1,600 for the tire thats cost $850 the labor i can swallow but the 47% markup i cant then they wanna try charging me for a whole end assembly on the bent disk the spool all the hardware something like $600 for a $23 disk the whole end assembly fell off on a 125 acre parcel disking loose open land i cant see how the whole assembly came off other than mechanics error you bet there trying to charge me for that to one of there sensors went out theres another $400 bill just amazing $1,400 dollar rental turned in to $4,300 i can swallow the tire and the disk but just gets under my skin about everything else just releasing some frustration
Well ive always found if your looking for advice you get alot better responses if you can come even remotely close to using proper punctuation. When you spew out a 200 word run on sentence it makes you look like a flaming retard and most ppl wont take the extra 20 mins it takes to reread it 15 times to try and make some meaning out of it.Did not realise one needed a honors degree in engish to post here........
I think I fixed them all for you OSG.:thumbsup: Just trying to help.I recently rented a machine. My operator had a couple errors bent a outside marker disk n cut a front left tire.
Man, are they really hitting me hard with this bill. They charged me $1,600 for the tire that costs $850. The labor i can swallow, but the 47% markup i cant.
They also wanna try charging me for a whole end assembly on the bent disk. The spool and all the hardware are something like $600 for a $23 disk.
The whole end assembly fell off on a 125 acre parcel.disking loose open land
i cant see how the whole assembly came off other than mechanics error. You bet they're trying to charge me for that too.
One of their sensors went out, there's another $400 bill.
It's just amazing that a $1,400 dollar rental turned in to $4,300. I can swallow the tire and the disk, but it just gets under my skin about everything else(just releasing some frustration).
