I have to relocate a toilet in a bathroom remodel and I need to cut off the existing elbow and closet flange from the main 4" stack and remove the pipe from the fitting then extend about 5' away from the stack.
From the stack they elbowed 90* right up to the toilet location. Cutting the stack fitting out and replacing is not an option.
So that being said do I
A) bight the bullet for a 4' Ram bit for one time use
B) hacksaw and carefully chisel the cut pvc piece from the pipe bell
C) get a heat gun and try to heat the piece inside the bell until I can remove it with a flathead screwdriver and needle nose
