Pretty common problem that I normally would just scrub down with a good dose of TSP but in in my haste to get started I realized I had no TSP.
So instead of running off to the nearest box store I used oxiclean. Worked fine enough, but now it seems I have a slightly chalky residue on the walls ( oxidation layer Im guessing)
Question is: Will this interfere with Kilz /paint adhesion? should I rewipe the walls using water ( or some other solution) to remove the chalkyness or just skip the rinse and Kilz it?
