1 - 5 of 5 Posts
G
How do u caculate the amount of dirt to be remove from ahillside if i want to tier it off
Each section will be 70 ft long *3.5 ft high....then it will go back 4ft and start another wall.... Another 4ft an another wall (total 3 walls)
A little math is going to get you close.
The area of a triangle can be found by multiplying the base times the one-half the height.
area = 3.5 feet * (4 feet /2)
area = 7 square feet of area per triangle, and you have 70 linear feet so (7*70) equals 490 square feet or (490/27) = about 18 yards of dirt.
I'd figure it this way:
70 feet X 3.5 feet X 4 feet = 980 sf
980 x 3 walls = 2940 sf
2940/27 sf (one cubic yard) = 108 cubic yards without swell
I figure you'll be using geogrid to help retain the walls. Therefore, I
figured you have to do use bench cuts for them.
Peace,
Rex Mann
I came up with 54 yards total and you came up with 108? Somebody is off. :cheesygri
Getting even more precise don't forget the dirt that will be removed from behind the walls if you install drain tile and gravel also.
1 - 5 of 5 Posts
