Ok all you excavation pros. How would you go about removing this wall?
Situation:
Not sure about the use of rebar when the wall was built, but I'm sure the footing was undersized or improperly designed. Plain and simple, it could last another 10 years or another 10 minutes, but when it comes down it takes the garage with it.
Obviously, excavators want to park a track hoe on top of the wall and knock it out one scoop at a time. The conditions suggest the possibility that the weight of the machine will cause the wall to fail. Also, the neighbors would have to agree to the hoe tearing up their yard, which is unlikely to happen. The hoe can't come at it from below because it will destroy the driveway and the powerlines are so restrictive that they would probably have to be taken down to work with a machine that large.
I had suggested using a rubber tire backhoe loader, starting at the front boundary and remove a 5' wide swath of ground behind the wall about 7' at a time. Brace the wall. Then use the bucket on the backhoe to push the small section of excavated wall toward the hillside. With any luck, the use of rebar would be light and that should break up the wall pretty easily.
Other suggestions have been to do the same kind of thing as above, but use a jackhammer to break up the wall instead of just pushing it over with the shovel. Also suggested was using a skidsteer with a concrete breaker attached.
What do y'all think. What is the most efficient way to remove this wall without it falling into the house in the process or costing $20K to do?
Situation:
Older home: mid 1960s
Retaining wall: 55' long X 8' high X 12" thick
Material: poured concrete
Wall starts at front property line and runs along driveway and side of garage until terminating in backyard. The section that runs along the side of the garage is located approx. four feet away from the garage. At least that is the case at the base of the wall. Eight feet higher at the top of the wall, the hillside has pushed it in so that the top of the wall leans in almost two feet. Here in northern Utah we have heavy snow and roudy freeze/thaw cycles. Retaining wall: 55' long X 8' high X 12" thick
