1 - 7 of 7 Posts
I guess I'll start with why grout a toilet base in the first place ?
However my question is how to remove a toilet that has been grouted in - say to a ceramic tile floor ?
Will it release satisfactorily without breaking the toilet base ? Any other tips ?
I have read that in some areas caulking the toilet is code. The way I understand it, it is to keep water from say a shower from infiltrating under the toilet.
UPC and every code depending on the UPC, including California 2010 Plumbing Code
407.2 Joints. Where a fixture comes in contact with the wall or floor, the joint between the fixture and the wall or floor shall be made water-tight.
Around here, that's interpreted as "caulk the toilet to the floor."
I've seen them grouted, too. Utility knife or MM. Sometimes driving a shim under it releases it. I've never seen one break.
here is is to ensure sewer gas does not get into the room if the seal fails. I always leave a small opening in the back so if it does leak you will see the water.
My plumber would rather see grout than silicone or worst yet phenoseal
1 - 7 of 7 Posts
