We will shortly be wiring up 2 refrigeration cases in a super market. Is it possible to run a numbered multicore cable out to the units from the refrigeration control panel with one common single 2.5mm sq earth, or is this not sufficient and we should run another earth.
Thelightsdraw 6A, the fans 4A, and the solenoid 1A for the units combined. Each circuit will be protected by 10A breakers. The units are like fixedappliances with a terminal strip inside
