1 - 20 of 29 Posts
Capra Aegagrus
Remodeler
Our kitchen sink (and dishwasher) is far enough away from the main heater that it takes two gallons and nearly two minutes to get hot water.
I'm thinking about installing a point of use heater (NOT tankless) under the sink in series with the main heater. Anyone have a recommendation for a good durable unit? I'd just as soon use 240V, but can go 120 if need be.
Capra Aegagrus
Remodeler
What will you be using it for? Do you just need it for your hot chocolate? The Franke instant hot water and filtered water dispensers are nice, but they are a pain to install.
I make hot chocolate in the microwave. No, this is just so we don't have to stand there and wait two minutes before washing our hands or a couple of plates.
Rheem RTE - 9
Thanks Mike, but I specifically don't want tankless. I have yet to become a believer.
Capra Aegagrus
Remodeler
Discussion Starter · #9 ·
Not only am I not convinced about tankless, I only have 10 gauge wire to the location. I tossed that in during my kitchen rebuild as a spare circuit just in case, and just in case has arrived.
Looks like I could fit the 6 gallon Rheem pretty handily, and that should have plenty of reserve until the main hot water arrives. Any caveats?
How are you planning to hook up both and have them draw?
That's actually pretty clever Tin. I penciled out some scenarios. Forget that formula, it's irrelevant.
Obviously you will have instant hot water. As you use the water it pulls from the big dog feeding replacing water used from the little dog. Go it.
Recovery is complex because your water rise is unknown. Lol.
So scratch even trying to calculate it.
OK. So the water replacing the small unit is gradually getting warmer until it eventually turns hot.
Hmmmm, I don't see why that wouldn't work. You are really not competing temperature wise so it isn't gonna cause any problems. The beauty is, with this system the recovery doesn't really exist on on he small unit because the big heater is replacing it with hot water.
Dam, I'd like to put this in for you just to see it work. Lol
Capra Aegagrus
Remodeler
Discussion Starter · #17 ·
Yeah; it would be variable. I'm leery of trying it with only a 2.5 gallon heater because I doubt that's enough reserve to mix in 2 gallons of cold and have it keep up until the line is loaded with hot.
Input much appreciated, Mike. Now all I need is one of those elusive roundtuits.
1 - 20 of 29 Posts
