1 - 1 of 1 Posts
Dear contractors;
I present to you the new Meterwork app that saves in rebar cost estimates...
Enter the quantities & lengths of the rebar parts needed in your construction process, the app will make combinations that minimize the wasted amount and lists to you in what lengths should every rebar bar be cut. The wasted percentage may be less than 1% in average. Of course this applications saves money, time and effort doing the combinations manually.
You can use this application in other meterwork usages rather than rebar estimates, that could fit to the same idea !!
Note:
You can optionally enter the inputs by loading a text file like the text samples attached with the app installation (SampleXXIn.txt). Also you can save the result to a text file like the text samples attached with the app installation (SampleXXOut.txt).
Download your free copy version 2.2 form Rapidshare.com,
link at; files\429029075\Rebar_2_2_3.rar
Windows OS is required.
Best Regards;
Tamer
1 - 1 of 1 Posts
