1 - 20 of 29 Posts
GRIZ... Looks GREAT.....
Pardon my ignorence.... but could you explain that assembly to me...
looks like 3/4 solid (obviously not prefinished).... and if it's floating it must be a TnG "glue-up"... so how do you keep your TnG tight... raw unfinished can't come that true, can it.
What type of underlayment/cushion did you use.
Thanks.... My flooring is limited to naildown solids and floating/glue-down engineereds...
Merry Xmas
How many on the crew, how long did 8800 take ya?????
Retired Moderator
Hey Peter,
The floor sets on top of 7/16 OSB which in turn sets on top of 2"x3"x4' sleepers. with cushion pads attached, that float on the slab (on top of vapor barrier).
Three guys put this down in 4 days.
One question, I remember you saying a bunch of time and money was spent leveling and grinding that slab, couldn't all the variations of been fixed with the subfloor material?
Retired Moderator
Discussion Starter · #14 ·
No. Manufacturers spec, 1/8" in 10', because it is a floating floor. Bad slab on a floating Gym floor makes a nasty thud when a BB bounces off of it.
Is it really possible to get a floor 1/8" in ten feet with a screed alone?
only 1 layer 7/16 OSB?
what sport system is this?
it wasn't a double offset layer?
every suspended sport floor ive done required 2 offsetting layers.1 strait 1 45 over the top.
I cant any system utilizing only one layer 7/16..
were the screeds fastened to the OSB prior to install?
Retired Moderator
Discussion Starter · #18 ·
Yes.
Horner.
No, single layer, runners 12" OC.
No, they float. Runners laid out then OSB installed.
1 - 20 of 29 Posts
