1 - 16 of 16 Posts
Two car garage must go. What's the best way to raze one? I don't want to reverse the building process when it was built by starting at the top removing the roof then the walls etc., etc. I'd rather just push it down. But how? Cut every other wall stud on opposite side of where we're going to push it with back hoe or start on top and push down? We can't torch it for there are telephone wires nearby.
Rent a mini-ex with a thumb to pull it apart and load it in dumpsters or dump trucks.
Use your backhoe to push/pull it apart, then use the loader to load it into dumpsters or trucks.
Rent a bulldozer and push it over.
In short take something with a diesel engine and hydraulic atachments and have fun. Beat it apart.
I watched a guy demo a garage one time. He slid a dumpster right into the stall and just went to town with a backhoe.... Tore it down and loaded it up in one step.... Thought it was pretty clever.... It was just one stall you might need two dumpsters....:thumbsup:
You don't need/want to remove 2x4's, just remove whatever is resisting racking forces on the two sides you want to fold. Set up some temp bracing then take out the t1-11, sheathing, let in bracing, whatever. then push or pull it over.
We moved a two car garage once to a new foundation using a crane. I wonder if you could strategically rig something, hook it to a crane, and rip it inside out. Maybe grab the door header, lift it, raise it up maybe 40 feet, and drop it??
1 - 16 of 16 Posts
