1,141 - 1,160 of 2,280 Posts
It hasn't effected business. So agree to disagree.
Times are busy right now so builders take the help they can get. When things slow down and guys are fighting for work people who do hack work will be getting fewer phone calls. Also why are you letting the builder dictate the price to you? If you know what it cost to do the job the right way then stick to your guns and tell them this is what it cost and this is why I'm the best guy for the job. As a GC I might tell a sub this is what I have budgeted for your trade, but that doesn't mean I always get my way.
I still don't get how it is faster to not wrap corners?
Around here If you dictate the price to the builder you will be sitting at home with nothing to do. These guys do hundreds if not thousands of homes every year. They dictate the price. It's take it or leave it. If you are a framer you Pretty much have to take it or do something else in life
mrcharles said:
I don't understand how not wrapping corners saves time?
When you sheet the butt walls on the ground it won't cover the corner stud on the bye wall.
I just sheet bye walls on the ground, and the middle of the butt walls. Then fill in the ends after walls are up.
I also sheet over the rim boards to tie it all together.
But as far as walls pulling apart if not over lapped I disagree. That's what the double top plate if for.
exactly. the past few years we definitely had to drop our price on most jobs. we still did everything the right way even if we lost money. never cut corners. last year we framed a house for a builder in his 9 house subdivision. framed it cheap as hell and didn't make any money on it, but still did the right job. next 2 houses he found a cheaper crew to use. they butchered the hell out of those houses. his buddy who was looking for a framer walked through the 3 houses and said "I want the framer who did THIS one" when walking through ours. we framed a house for him in the fall, trimmed it out for him 2 months ago and now he's got more houses for us. cause he wants quality and he saw it in our work. it doesn't matter what you're being paid, your name is still on it and it affects jobs down the line. separate yourself from the pack, don't stoop down and blend in. right now we're so overloaded with good paying work it's ridiculous. because these GCs have used the cheap crews and saw the difference.
Just overhang your sheet, it's not rocket appliances.
forgot to add that while we were framing the house in the fall for the new builder the rep from the lumberyard he uses came by and looked at our work and took a bunch of our cards and has since given us a few jobs/new customers and continues to do so. doing the right thing doesn't always pay off right away, but over time things usually work themselves out.
Absolutely never lower your standards, it will pay off!!
All gets covered and you will never see the beautiful framing.
Back in my framing days, clean beautiful framing was why we always got called back by the general who appreciated pretty work. It was also a reason we could get top dollar for our work.
Rushing these 2 up and have a third house beside these with a walkout and first floor on using as a prefab table. Trusses are up on the walls. Got the loft section to build still. Moving along good on these we are a week in. Back roof is on and sheeted and mostly all back framed inside.
These two are the same model just different elevation on the front. About 2700 sq each.
Just a question, but are you not taping your joints because its siding guys job or are you not supposed to. I've been seeing more and more guys with no tape and wraping the house in tyvek after which looks like a PITA.
Looks like we are the only guys here using Atlas Board!
We are not required to tape the seams of the sheeting. Have worked for a couple custom guys that wanted it taped as we went.
A lot of the other foam board products we use have ship lap joints. The atlas board (rx as it's called) is the only one that isn't.
Where in ontario are you from?
I'm from Chatham, half way between Windsor and London.
So you are just using the isoboard as a insulator then? Seems that ship lap would be a lot cheaper. Our system is engineered so that the isoboard is the outside wrap and the vapor barrier all in one.
