981 - 1,000 of 2,280 Posts
Typically it's top chord bearing floor trusses (16"-24" in height depending on span) 16" o.c. Sitting on double 2x ledgers. Then you would add 2x blocking at the perimeter between floor trusses and Tapcon those to the masonry.
Tapcon :eek:
I would expect it to be cast right in.. epoxied or with expansion shields.
With icf is anchor bolts cast in.. with hangers or (in your case) top chord bearing trusses. I like those things :thumbup:
Tapcon :eek:
I'm sure the ledger is bolted on. The blocking would be tapconed - it only would be serving to prevent the floor trusses from twisting or rolling.
Dirtywhiteboy said:
Nice shots there:thumbsup: is that Tampa Bay in the background? Will that building get a soffit around it?
No, it's sarasota bay. It will get a soffit. Upper level trusses create the soffit because the bottom chord runs out. Lower level, we'll have to go back and frame it in. I've seen a lot of guys on here that frame the soffit before they set the trusses, but our truss company is so hit or miss it would be too much of a gamble.
FramingPro said:
Tapcon :eek: I would expect it to be cast right in.. epoxied or with expansion shields. With icf is anchor bolts cast in.. with hangers or (in your case) top chord bearing trusses. I like those things :thumbup:
The masons embed j bolts into the tie beams and we set our ledgers to those. The blocking that gets tapcon'd is just pressure blocking that also gives us a perimeter for sheathing diaphragm nailing.
Some SE's do away with the ledgers and have us use hangers. That's a lot of drilling and I usually try to encourage the contractor to have them switch it to ledgers.
Actually looking at it I could have gotten rid of one or two cripple studs above the header on the left and just kept the one for layout. Plate said JJKKBBBBKKX. All 2x8. The blocking it the 8' mark on the 16' wall.
I just found this pic buried and I always liked how this column looked. The owner said, "so much for super-insulated."
