Random Framing Pics Thread.
481K views 2.3K replies 213 participants last post by  Dirtywhiteboy
#1,775 ·
Years ago we slid an eighteen foot tall by ten wide off a house. Doorway wall on a split. Got it halfway up, decided we didn't have enough guys and started to bring it back down. Teeter-tottered, bottom plate pulled loose, almost crushed a guy, and off the house it went. Guy I was working for had a coronary. Never trust a newby to tack the bottom plate.
#1,785 ·
Mine are just like these. I have three of them. Two 18 footers and a 24 footer. I've lifted some serious walls with them. Last one we did was 30 foot long with a gable spanning the 30 foot with a smaller gable on a bump out spanning 15 foot. We lifted it with windows, layover siding, trim, corbels. Only thing it was lacking was one bird box.
I like those one you have. Ill tell ya one thing. Mine sure as hell wont fit in my tool box.
#1,789 · (Edited)
Why is your sub fascia nailed between the rafters like blocking, instead of continuous and through fastened to the tails?
And looks like the left side stucco was cut out quite a bit more than the right, so on the right, some of the framing is on top of the stucco?
#1,797 ·
This sill plate at bottom of door is perfect example of my way. Most guys just pull old door out and put new one and put shims and foam between sill plate and bottom plate of new door. I never do it. Pull out sill plate and reframe below it to be perfect level. It is not easy as usually everything is crocked there. Second problem is that it take much more time but I keep my level of quality no matter what. Hence lost countless exterior door replacement jobs. Customers prefer save 100$ and have crappy looking entry door for next 30 years. I never try to explain to them.
