Trusses freespanned 40', with a consistant 1/8" crown up on the bottom chords. However the purlins were originally 2x4s with 2" notched out of the bottom, possibly to keep them from rolling? The purlins had about 2" of sag in the center. The owner wanted to rip and reroof, but wanted the sags removed first. Brackets were welded up to hang from the top of trusses, bottle jacks were modified to slip under the 2x10s, onto the brackets and lift into place. Relief cuts were made in the purlins one at a time. The sheathing was a mix-match of anything they could find at the time, so Zip sheathing was installed to float out the imperfections and unify the roof.Lone,
Amazing how those old framing members carried such a wide span!
How wide was that one?
What is the newer framing for?Insulation and sheet rock?
Ikea?:whistlingAnybody can cut and fit dimensional lumber where you can strike a nice pencil line where you need to cut it. :whistling
NjNick;872112 @ lone - I have never seen those metal wall studs that look like trusses. Whats the brand and whats make them different than traditional metal studs? [/quote said:The entire framing package was the "Frame Rite" system by Marinoware. All the studs in this home are structural, whether load bearing or not. I don't particularly care for the open web design of the studs, because in many cases, the holes arent where you want them and it's a real bear to punch 'em where you want 'em. The owner opted for I-joist roof rafters rather than the steel option that is also offered by Marinoware.:thumbsup:
