Random Framing Pics Thread.
480K views 2.3K replies 213 participants last post by  Dirtywhiteboy
#1,078 ·
They are railing brackets for the second floor. They are two pieces. A bracket and a pole. Made of aluminum so no rust and light weight. Attaches to a stud and top plate, we use the structural screws all 3 of them. Brackets extend out to work around the second floor brick-siding can't. Railings start 11" up so technically (if we used it) the toe board would be at correct height. We just put them on every 8' and slide 1 2x4 in before we lift the walls. Add the mid rail from up top. Engineered safety and up here it's a very big concern for railings on the second floor, or first if it's a walkout.
For the cost of them, one fine would off set it so it seems like a smart decision.
#1,080 ·
kyle_dmr said:
Started this guy today. Not until 10 am thanks to a cold forklift not starting. Hour away from main floor done. Back half of the house is ready, all braced and leveled. Hoping to get some walls stood tomorrow. A lot of porch stuff to get ready. Ceiling joists galore
2.5 days in.
And a better picture of what the railing system looks like.
#1,082 ·
7 day house. Could and should of been done in 6. Lost half day because of no backfill and waiting on trusses. 2600sq plus 700sq garage 300sq of covered porch.
Picked up another pallet of nails. Burning through them like no tomorrow.
#1,095 ·
#1,100 ·
We got to go help a new client out on one of his houses. We will be starting a"small" house for him soon so he wanted to see what we can do. It was just a small deck and some punch list stuff, brackets on the post and beam, doug fir ceiling, hardwood flooring and some other stuff
Its a pretty nice house. It will be interesting to frame a house for him. He currently has his own framers but has gotten so busy, he hired us. He does VERY high end custom homes, usually with alot of post and beam. He said he has one job with seven guys that has been in the frame stage for just under a year!
Oh, here is a dormer i framed seeing as this is the random "framing" pics
#1,102 ·
just started this 7,000+ sq. ft. addition. the masons screwed up, and the steel guys screwed up. and guess who's job it is to fix it all? what else is new. gotta cut 250+ studs to custom sizes to frame the outside basement walls. I'm sure once the floor is poured and we frame the inside walls those will all have to be cut to size too.
#1,115 ·
snapped this pic before lunch today. after lunch we got up all the 12'6" walls. all the walls in the picture are 9'9". so yes, we've had to cut every single stud on this job so far. plus we lost a few days to rain and a few other days to pull off to go to other jobs. and we're not allowed to work there on Saturdays. very slow going job for us. we're used to flying.
#1,104 ·
The plan called for 9ft precuts in half the basement, but the foundation is 1" 5/8ths too high (can only use single plate on the 2nd floor where it ties into the house to match the existing floor instead of 2 plates). guess it's too hard for the masons to cut a small hole in the side of the house to make sure they get it right.
#1,108 ·
Not sure about your situation but in my experience the cost of the machine will often offset the cost of jerry rigging some scaffold or something... plus its legal.. Definitely outweighs the cost and consequences of safety fines for questionable scaffold or staging set ups :whistling
