No, it's sarasota bay. It will get a soffit. Upper level trusses create the soffit because the bottom chord runs out. Lower level, we'll have to go back and frame it in. I've seen a lot of guys on here that frame the soffit before they set the trusses, but our truss company is so hit or miss it would be too much of a gamble.Dirtywhiteboy said:Nice shots there:thumbsup: is that Tampa Bay in the background? Will that building get a soffit around it?
The masons embed j bolts into the tie beams and we set our ledgers to those. The blocking that gets tapcon'd is just pressure blocking that also gives us a perimeter for sheathing diaphragm nailing.FramingPro said:TapconI would expect it to be cast right in.. epoxied or with expansion shields. With icf is anchor bolts cast in.. with hangers or (in your case) top chord bearing trusses. I like those things :thumbup:
I put one of those as a ridge on a guest cottage. No fun at all.FRAMERBEN said:24" lvl 25' long. Phew......
That's the Golden Gate of thermal bridges.I couldn't do any fewer.
I'm sure you can explain this. But why?Golden view said:I couldn't do any fewer.
I'll guess another beam gets dropped in the topCaliforniadecks said:I'm sure you can explain this. But why?
That's such a ridiculously handsome stud column.Golden view said:I couldn't do any fewer.
That home was for the local orthodontist, there's a lot of money in braces.MTN REMODEL LLC said:Yeah Cali...... Very nice..... I thought you were a primary, maybe exclussive, decking operation. How much new build do you do out there in earthquake country. Just curious... Best
