Random Framing Pics Thread.
481K views 2.3K replies 213 participants last post by  Dirtywhiteboy
#624 ·
yeah haha, i cant remember what the exact problem was but i remember our neighbours had to move their roof forward an inch and our roof back an inch...but another problem was the party truss...it was a triple with 4 layers of drwall i think...and the trusses weren't identical... so we had to plane the high spots..only on the firewall though..i cant remember exact details becuase i just started and was learning at the time..
#638 ·
Wow. That kid you would be down the road. Guys who say rough framing or rough carpentry around me get to have an early lunch. Theres no such thing it takes just as long to make it right than to hack it in.
Ive seen alot of guys with that attitude make alot of money, I've watched the same ones starve out when things slow down. They only get the jobs where low price wins. Those houses are the first to cut back production at a hiccup. The customs keep on going but hacks dont get to touch them. They loose there business and get to go work for someone else, all over having the rough carpentry mindset. Costs you money in the long run building always runs in waves better to always be on top!
#639 ·
Dan, the best way i can describe it is that you have to "walk the fine line between production and perfection"
Although there is a push to get it done, don't settle for less, find ways to incorporate quality techniques and procedures into the hustle and bustle. Anyone can slam the **** together fast, but what separates the true framers from the "rough carpenters" is the ability to turn out a quality frame in a timely fashion.
Just my 2 cents. :thumbsup:
#640 ·
Nicks right.
However, as an employee, you also have to do what your boss says. You can protest against it, but the end of the day, he is the one that signs your cheque. That is also a fine line. Doing it to your standards vs. what the boss says and in the time frame the boss says. Now, if you can make good and tight, and have it done in the time frame dictated by the boss.... give 'er. Sometimes, you just have to know when to (for a lack of a better word) hack it together and when to make it pretty.
#641 ·
Man that speech sounds vaguely familiar
#648 ·
FramingPro said:
I don't think thats really relevant, whether it is 1 or 100, my views remain the same.
I think experience is the most relevant thing in this industry. Until you have worked your way around all of the problems that can come to pass from time lines to technical problems your views can always change. I'm not saying that quality or efficiency should ever suffer but never say your view on things can't change because at that point you stop learning.
#650 ·
I think it really boils down to one question. "What are your tolerances?" Is it the width of a pencil line, chalk line or the beam of your laser? Is it dead nuts on, or is the bubble just between the lines? When are those tolerances more important than other times? If I try to square the house on the foundation, does that help anybody if the frame is hanging over 3/4" on one corner? Wouldn't it be better to be straight and parallel than square if it just means you're out of square a sixteenth every 4 feet? How can your tolerances be more than the variation in your lumber, like when CCA 2X6 tends to be 5-5/8"X 1-5/8"? Or 10' 2X10's always being 9-3/8" while the 16's are 9-1/4"?
Don't get me wrong, I strive for perfection. Even then things can try to get away from you. An eighth off on the first floor usually grows to a quarter at the top of the second. Sometimes you have to know where you have a little more slack. Not in kitchens and bathrooms, that's for sure. but a quarter inch out of parallel in 36 feet on a bedroom gable end? I can probably live with that.
At the end of the day you ask yourself, "Can I live with that? Can I sleep tonite without it bothering me half the night?" Almost always the answer is yes. But on occasion, the first things I grab in the morning is a catspaw and a sawzall to fix something I can't live with. Why is it always the first thing in the morning when I take a shower in sawdust?
#654 ·
Ya being square is most important Starting with squaring foundation Take the time pull your diagonals tolerance to shoot for is 1/16 inch from sill plates up to rafters stack frame everything Use lots of string. Make cuts for hips valleys tight so you can't slide a peace of paper in it. If you are in the custom house game it means everything. Anyone can build a box and set some trusses and the price reflects that. It's a different game when you are building custom roofs with multiple bastard hips and valleys. I can understand the "good enough" attitude in building track homes but don't like it
#661 · (Edited)
Sure they should. 3//4' is a bit too much for my liking, but I can deal with it. But like I said, who does it help if I'm hanging over the foundation that 3/4" on one corner and in the same on the other?
You said within reason. I get that. Before you said a sixteenth. I just think that's asking a bit much. Do you understand significant digits?
Look, I said before I try to get things as close as I can, but some material and equipment tolerances only let you get things so close. A good framer does the best he can with the foundation he is given to give a quality product and watch out for those following him.
