=Slyfox;401056]I swear i never once ever used the word "stacking" until i posted here on this subject,
So if a term doesn't exist in "Ohio", it doesn't exist?
Ever heard of "alligatoring" or "fishmouthing" or "telegraphing"?
With Gutters, the pipes coming down from the gutter are technically called "downspouts", but we ('round deez here parts) call them "leaders".
:blink:"2ndGen is a bad influence":blink:
:laughing::laughing::laughing:
I saw a picture here in this forum once were a guy was lifting a laminate up at the lower left corner so he could show a pic of the flashing work underneath at the eave and thought "wow" that lower part of the shingle is going to curl up and look horrible in a few years after he bent it up like that, but i didn't reply to him about it because i didn't know how to say it with out seeming rude so i just left it alone.
What would make that particular shingle act differently from the others? Once that sun heats it, it seals back down (unless forcefully pulled up by winds or by hand).
But i guess i mentioned that now because that could fall into the catagory of causing cracks in the laminates when lifting them to high or in cooler weather to get that nail underneath.
Technically, shingles shouldn't be installed in weather so cold that they become brittle. I generally don't work below 50 degrees. The ARMA suggests they not be installed below 40 degrees.
"The Asphalt Roofing Manufacturers Association (ARMA) says shingles become less flexible at temperatures lower than 40 F and more prone to cracking during installation."
http://www.professionalroofing.net/article.aspx?A_ID=1206
I call the water cuts in the 3-tabs "bondlines", whats the proper term?
Good question. I've heard cutouts, keys (though I don't know why), slots, but generally, cutouts are the accepted term.
I'm interested in hearing what other terms might exist throughout other parts of the country.
