1 - 20 of 31 Posts
Multiquip diesel 7kw.
http://www.multiquip.com/multiquip/DA7000SSA1.htm
These are even more money then the honda option. Might not be as quiet as the inverters don't know at that wattage. Compared to a honda or wacker neuson 5600 watt it is very quiet. 20' away can barely tell it's running. They are quiet large and heavy though so take that into consideration.
What are the power requirements? Power tools or?
The Ultimate Wire Hider
There are videos on Youtube where people retro-fitted a car muffler on the end of a standard Briggs & Stratton powered generator. Not only was the generator relatively quiet but they could also use it inside of the garage while exhausting it outside.
90%-er
Discussion Starter · #10 ·
Maybe some context will help. We're two weeks from being done with turning a 31 foot Airstream land yacht into a mobile cigar lounge that will be available for rent for weddings, corporate events, private parties, etc.
Power requirements are for the air conditioner, 6 LCD TV's, ventilation system, two electric heaters in the winter, Playstation, mini-fridge, and a large humidor.
I was thinking 5000-5500 would do it.
The entire thing will run off a whip that comes out the back end and plugs into what will hopefully be a very quiet generator.
We've got about 35k into this thing already, and I was hoping to keep the generator down to under 2k if possible.
Another suggestion we've had is to use a regular generator but build a vented "dog house" style housing to go over it. But I was thinking that wouldn't do enough for the noise control?
Contractor of the Month
This term "inverter generator" is new to me. What's the difference between these and the regular old generator I've got out in my trailer?
A traditional generator is a motor connected to an alternator. An inverter uses a 3phase AC generator that is converted to DC then uses an inverter to create 120V ac.
The result is cleaner power that you can run sensitive electronics off of. Also they are more expensive, more complicated, quieter and more compact.
Capra Aegagrus
Remodeler
And instead of running at a fixed speed to maintain 60 Hz, they can throttle down when there's low demand--meaning less noise and lower fuel consumption.
For fuel consumption the diesel option is the way to go. Powering a 7 man framing crew, we burn 15$ a day (10 hours) in fuel. That is pretty hard to beat. Even at full speed they are quiet with the sound enclosures. The 1800rpm ones are quieter yet, but only come in bigger sizes 15-20kw is small.
1 - 20 of 31 Posts
