200 amp service panel for house is in North end of 60 foot long ranch house in full finished basement.
New pole barn garage is 12 feet away from South end of house. Customer wants 100 amp sub-panel in new pole barn.
Plan is to go thru basement wall, underground and up thru the floor of the new pole barn garage.
What materials do you suggest for the most economical installation in terms of cable, conduit, disconnects, panels and breakers.
Should I install a main disconnect inside the South end of basement right before it goes thru the wall because the cable type would change or no because it is not necessary? Customer does not care as long as it is functional.
What is the best way to drill thru a poured wall to install conduit and then waterproof around the conduit?
