In a thread started by Wallmaxx on two sets of stairs he had to build the thread developed into sizes for treads and riser's.
So I had a question but didn't want to high jack the thread so I put my post here. I agree with all the comments made on the other thread except for the word aesthetics .
It's not by chances that the size of the tread is related to the size of the riser.I always thought it was Leonardo Da Vinci who thought up the formula
but another guy told me it was a French Architect named Blondel can't really comment on that,the only French Architect that I know of is Mansard.
Any way its worked out for the ease of climbing stairs.It goes like this 2 rises and one tread should come to 65cm (26") so with 2 risers of 17.5cm(7") the tread will be 30cm (12").
Like every thing else in this world it some times has to be tweaked a bit to work out.BTW I'm not trying to teach my grandmother to suck eggs here but thought if just one guy picks that up its worth putting in.It goes without saying the stairs must be built to the code of where ever you are but it wont be far out from these sizes.
Any way this is the point I want to make when a architect draws a plan for stairs in the U.K. he will give a size for the tread say 11" this size is from toe of tread to toe of tread,he will then show a detail of the riser with a 1" over hang or in the case of concrete stairs a 1" rake back of the riser.
This 1" is to be added to the size of the tread to give you a size called "The Going" in this case 12".
I've never seen on a drawing where the measurement is given for"
"The Going" and I've seen this cause some confusion.
Is the term "The Going" used any where else in the world or is this a case of U.K. Architects just being a law unto them selves.
billy.
BTW thanks to any one reading this post to the end.
billy.
