Ok you have the answer, now how about the back story?:thumbsup:not a framer but have a question..is most of the north east 16 on center or 12 on center when it comes to framing walls on new homes?
Would 16" centres be the maximum? Could I frame at 24" if the wall wasn't holding much load? Example: I have to frame on the outside walls of a basement that I'm finishing. The top four feet of the walls are framed and are flush with the (poured) concrete foundation walls on the bottom half. I'll need to frame the walls anyways to hold the drywall and such, but since they'll just be hanging walls, do I still have to have 16" centres? Also, should I insulate the outside walls?
LOL :w00t:General contractor huh?
I would recommend using 96" o.c. You only need to secure the drywall on each end. Just make sure you specify structural drywall.Would 16" centres be the maximum? Could I frame at 24" if the wall wasn't holding much load? Example: I have to frame on the outside walls of a basement that I'm finishing. The top four feet of the walls are framed and are flush with the (poured) concrete foundation walls on the bottom half. I'll need to frame the walls anyways to hold the drywall and such, but since they'll just be hanging walls, do I still have to have 16" centres? Also, should I insulate the outside walls?
Insulate with Great Stuff gap and crack filler. Then you won't have to deal with all that itchy fiberglass insulation.I would recommend using 96" o.c. You only need to secure the drywall on each end. Just make sure you specify structural drywall.
Insulation...what for?Insulate with Great Stuff gap and crack filler. Then you won't have to deal with all that itchy fiberglass insulation.
It also provides heat as it decomposes!:laughing:Insulation...what for?
Just install the lower course of drywall, then have your wife and kids fill all the voids up with their daily trash - free insulation! Talk about green remodeling!
I would use Mc Donald's french fries. They're cheap, never rot, and then the whole room would smeel really good all the time.Insulation...what for?
you can get 12' sheets you know, that will allow for a 1/3 reduction in framing materials.I would recommend using 96" o.c. You only need to secure the drywall on each end. Just make sure you specify structural drywall.
Paper contractor that is just asking to get taken by a framing sub I'll bet.General contractor huh?
As a General Contractor you should know the answer to the question you asked.Is there a reason nobody else could offer information? I'm new at this, and just learning as I go. In all seriousness, is there an unwritten code of conduct between contractors in the US, that prohibits sharing of useful information between contractors? Like I've said, I'm new at this, but so far the contractors that I've come across here have only been so willing to help with the sharing of tools and information and such. I thought this forum could have been a useful tool for everybody involved. However, (with my first post) it seems to have proven just to be a source of entertainment for those who hold themselves in a higher regard than perhaps what is fair? Either way, thank you to those who took the time to offer helpful insight; to the others: I was going to apologize for the wasting of your time, until I realized it was by your choice (perhaps a lack of something else better to do), that you chose to laugh instead.
