1 - 11 of 11 Posts
Trial and Error Opperator
On a job, guy has requested 2 mil profile ....
I am using press-o-film, x-coarse so I'll be in tolerance of 1.5 to 4.5 mil
The guy bought me a hand tuned micrometer
( I wanted a spring loaded) but here is my problem.
I'm testing aluminum thick stock, using 30/60 crushed glass, 260 cfm, 90 psi at pot, #5 win (test dry and wet)
Need to know if I'm figuring right
Tape measures .016 new, measurement after
blasted= .006, three different test strip done.
So, .016 - .006= .010 is this 1 mil?
I want to be sure I'm moving the Dec point right?
Second problem, same test on steel L beam
I test and still get 1 mill
But looks and feels much less profile than the aluminum...
Am I going nuts or is the hand micrometer the wrong tool... which I think it is...
I think it's squashing the milo
Any input good or bad please
I have thick skin, so give it to me
Discussion Starter · #2 · (Edited)
Picture of micrometer and blasted aluminum
aluminum on left / steel on right
You need a micrometer specifically designed for profile tape. Also, you'll need course grade tape to find an average of 2.0 mil
Below is a vid for your reference.
That's pretty much the high and low of it. :cheesygri
This is the type micrometer that you should be using. The one that your using is just going to flatten out the foam on the tape giving you a false reading. Glad your not inspecting any of my work. Lol!!
Administrator
Sawdust follows Me Everywhere
Discussion Starter · #11 ·
Thanks Beny!
1 - 11 of 11 Posts
