Hello Pros,
I have a framing question. I have a little job where I will need to build 2 walls within a finished home to divide a room. I have done some framing but its not my specialty. the existing walls are 8' but the ceiling is not flat but rather a 12' cathedral style. I need to build these two walls to connect each other on the corner and I will be framing a rough opening for a door but the question is I know how to build the wall no problems if it were 8' with flat ceilings but in this case its not that way so what should I do for the gap between the 8' top of the wall and the ceiling at 12' how is this framed so I can make the room look good?
Thanks.
JGD
Thanks.
JGD
