1 - 1 of 1 Posts
I ordered some Quartzite stone panels (similar to the rock panels available through Norstone). Installation for interior feature wall with small library & wall mounted elec fireplace.
When the stone is delivered I see the "corner" pieces appear as a single piece rather than the conventional 2 piece corner. The sales-rep says the outside edges of the corner pieces are "different" from non corner pieces. He says cut the corner piece in the middle and use the outside edges together as a corner. This doesn't make sense because there are no dog ears to overlap! Both the corner panels and the middle panels look identical. Is there any method to install outside corners with this stone without showing the factory cut edge? :sad:
1 - 1 of 1 Posts
