1 - 7 of 7 Posts
http://www.armstrong.com/reslaminatena/prod_detail.jsp?itemId=74275
I'd like to have the above floor installed in my townhouse in the dining/living area, front hallway, and kitchen. This is a "glueless" floating floor, the best quality that Armstrong makes. The floor would be installed over a concrete slab, and even though the water table is low in my area (Virginia) I'm going to insist that the concrete be sealed.
A contractor I spoke with said that I don't want a laminate floor since if one piece gets damaged beyond repair, the whole floor would have to be replaced. I could see that happening with a glue-down floor, but couldn't a piece of glueless laminate be replaced by carefully taking it apart, replacing a piece, and putting it back together? Or, do people replace floors because the manufacturer may no longer be making that particular style/color any more, so finding a piece to match is difficult, if not impossible, and very costly?
Any thoughts appreciated. Thanks!
High end Armstrong is a good choice. The contractor was wrong, changing out a panel is not that difficult and you don't have to disassemble the floor. Save a few of the big drops and buy an extra box, store in a cool, dry place just in case. A different lot# can make a difference.
Ditto.
Flooring Guru
Ditto here too.
By the way, find someone with a different opinion.
The underlayment is key. You needn't depend on a sealer when you can simply buy a quality underlayment. I prefer a product called Sound Solution made by Healthier Choice in Dalton Ga. They have an iron clad guarantee.
Using 6 mil polyethylene is pretty cheap insurance toward avoiding moisture probs associated with laminates. Despite sales pitches to the contrary, none of them are very dimensionally stable.
CHU
Sealing the concrete is just cheap insurance. I noticed on my first job that just walking on the poly sheet can cause micro punctures due to a small stone in a boot tread or one trapped between the membrane and the floor. I spent a lot of time taping holes on that job. I'm pretty convinced that with 2 coats of sealer the vapor barrior is redundant but it goes down anyway for warantee reasons. I just think about what it would cost to tear it all out and start over. :cry:
1 - 7 of 7 Posts
