1 - 8 of 8 Posts
Any of you guys, when installing a new patio door, use azek as a sill plate or to raise the door?
I have spoke to some guys who refuse to use anything but flashed wood in those applications.
I also see some guys using Azek to buck frame a basement window opening; opinions on that?
The two contractors I've worked for use PT with silicone or pitch to seal the bottom.
Can azek be flashed with aluminum? Does it have the structural integrity to be a patio door sill plate or a sill plate on a wall( on top foundation)?
Yes, azek can be covered with aluminum. You can use it under a patio door.
I have used azek and 1/2" PVC facia under doors many times. Usually when trying to keep them up off of concrete.
The composite shims are nice because they don't compress, but they are a huge pain to cut off, they are too short, and too expensive.
KemoSabe
I have used PVC as a "carpet shim" under hinged entry doors as well as bucking openings in block walls. I just installed 2 twin windows in block walls over the weekend. 14" wide PVC was attached to the window frames, then set in the block openings and foamed in place. Worked like a charm.
These are the windows. The door was done in a similar fashion, along with carpet shim underneath.
Reactions: Hand Drive
1 - 8 of 8 Posts
