Gentlemen, I am a builder of 40 years. I have done numerous projects that requires retaining walls up to 12' high, but have a project in the San Francisco bay area of California with retaining walls up to 7' high and the owner wants a "perfectly smooth" concrete finish. The issue is we have the rebar of course, but also two rows of conduit with light and electrical boxes. The vibrator has to inserted and relocated gently with some areas unable to vibrate.
My preferred solution is perfect forms, built modularly for easy removal and, when necessary, I will even use a 1/4" melamine liner for a perfectly smooth non-stick surface. They concrete sub I am using "comes with the project," is primarily a structural steel guy, is young and I am not pleased with the wall form construction, joints etc. and have concerns about the final finish. The concrete contractor says not to worry as he will remove the forms after the walls have "setup" then float/finish them smooth. I asked him if he had ever pulled forms early on retaining walls to smooth finish them and he said "no." I asked how he knows when the concrete is set up enough to safely remove the forms and he said his finishers know.
I've been in this business and around people long enough to know when the risk factor starts climbing and have a number of concerns, 1. Lack of vibration in certain areas will likely result in air pockets on the finished walls that will require finishing 2. The walls are varying heights and thicknesses, so each should have its own "set-up" timing. 3. I don't trust this scenario and the potential for catastrophic disaster exists.
The concrete is 3,000 psi pea gravel for pumping. One wall is 13" thick x 12' W x 43" H. The second wall is 8.5" thick, 25' long and stepped to follow grade with varying pour heights from 40" to 84".
I'm thinking of not letting him remove the forms and deal with surface imperfections with a guy a know who is a great indoor (Venetian) and outdoor (Santa Barbara finish) plaster. If he can float them all smooth to look like concrete then great. If not we'll apply a texture.
Question is, is it possible (for the right experienced man) to remove retaining wall forms early enough in the game to finish them smooth or is there no way to do this safely?
I defer to your expertise.
