No. Additional plywood not required if I remember correctly.
If you use a plywood underlayment it must:Personally I wouldn't risk it. I would check the sub-floor seams and stiffen it up if needed. I would put down 3/8-1/2" AC plywood running opposite of the sub-floor then staple 3-4" on center with a few dabs of construction adhesive below. Then your modified thin set then the Ditra. Having a tile job go bad and having to tear it up later and redoing it is huge compared to a few hours of labor laying down the underlayment. Who knows if Aunt Betty is coming over for Christmas dinner and she just happens to weigh 400 lbs.![]()
If you are going to lay another layer of plywood you would lay it perpendicular to the joists, screw to subfloor but not to joists.Personally I wouldn't risk it. I would check the sub-floor seams and stiffen it up if needed. I would put down 3/8-1/2" AC plywood running opposite of the sub-floor then staple 3-4" on center with a few dabs of construction adhesive below. Then your modified thin set then the Ditra. Having a tile job go bad and having to tear it up later and redoing it is huge compared to a few hours of labor laying down the underlayment. Who knows if Aunt Betty is coming over for Christmas dinner and she just happens to weigh 400 lbs.![]()
That's ok if you live in Jersey :laughing:Why not wire or plastic mesh and self leveler?
That adds to 1/2
It is April Fools Day.That's ok if you live in Jersey :laughing:
I disagree, the underlayment and subfloor move separately from the Ditra and tile.If you use a plywood underlayment it must:
..be installed perpendicular to the joists. I meant joists, brain fart
..be a minimum of 7-ply (regardless of thickness). Agreed, but keeps the height down for the transition at the door
..free of any construction adhesives.
Not sure what you are disagreeing about. All of my comments are based off industry minimum standards. To disagree with them is to disagree with an entire united body of manufacturers and testing facilities that create these standards.I disagree, the underlayment and subfloor move separately from the Ditra and tile.
