1 - 12 of 12 Posts
Would like to have accent lights on a programmable multiway switch.
I bought one, set it up without looking at the instructions because, well, it's a 3-way as the package states, right?
Well, it's not. Apperantly all programable 3-ways opperate in conjunction with a single-pole switch that sends a relay to the programmable switch that opperates as the toggle to the load.
Does anyone have any knowledge if there's actually a programmable 3-way that will work with a real multi-way switch setup; example being 4-way setup?
Any help would be awesome!
Contractor of the Month
No, only ones I know of work with a "load controller" master and a "remote" slave.
Looks like Lutron's Vizia series has a multi-way feature, even though I don't believe it's a real 3-4-way series switch system.
It's too bad because I wanted to leave the lever style switches. :(
Gonna call them first thing in the morning and see if their system will serve my purpose.
I've run into those in some of my customers homes. They don't work and it is above my skills to fix.
I've had to call in my electrician to trace the wiring to repair the original job for them to work properly.
Good luck.
My wife still can't figure out why when she holds the switch down a few seconds instead of taps on it the lights don't shut off as quickly.
I can't figure out why she just doesn't tap it.:blink:
Tom
Mine thinks they only go on and magically turn themselves off.
1 - 12 of 12 Posts
