Was on my tractor today and went to put it in 4wd. Pulled up on the lever and it pulled up way too far and seems the connection inside the t case has come apart. It will drop back down but it definitely isn't connected anymore. Exterior linkages seem ok. There is what looks to be a small access plate where the lever enters the t case. Might I be able to remove this to see what I'm dealing with? Just have no experience with this. Most likely going to go to a shop, but I know it isn't going to be cheap regardless of how easy the fix is. Is it even safe for the t case if the tractor runs if something loose is inside there? Thanks, Nick.
