Problem replacing old baseboard heater
2664 Views 7 Replies 5 Participants Last post by  KennMacMoragh
Customer wanted an approximately 50 year old baseboard heater replaced. He claimed it worked, but half of it was gone, so he wanted a new one. I pulled the old heater out and found three two wire cables going into it; the supply line, the line going to the thermostat, and the line for continuing the circuit. So I figured out the proper connections, hooked it all up, it worked fine. Later on, homeowner says it doesn't work. So I tested the line going right to the heater, sure enough, it wasn't getting any power. I pulled everything apart, re-tested the supply line and still got 240V, so I pulled out the thermostat and hooked the wires together to bypass it, that would exclude the possibility of the thermostat being the problem. I checked the other end of the cable between the thermostat and the heater with my ohm meter, and it showed continuity, pulled the wires apart on the other end, checked again, continuity is gone, o.k so that part is fine. So I tried hooking the supply power line through the cable between the heater and the thermostat while I still had the thermostat pulled out and bypassed with a wire. Checked the leads going to the heater, read 240V, o.k good, I pulled apart the wire I had crossed in the thermostats j-box to open the circuit, then it dropped to 200V, while I was expecting it to go to zero. My consensus was there was something interfering with the cable between the thermostat and the heater. But I couldn't see what it was because everything is buried behind drywall. So I tried hooking everything back up like I had it to see what would happen. But I didn't mount the heater back on the wall, I just left everything exposed yet connected so I could test it. So I got the thermostat back in, heater connected, put my volt meter on the line in at the heater, turned on the thermostat, I read 240V and the heater turns on, o.k good. So I turn off the thermostat and expected it to go down to 200V like it did before, I turn it off and meter reads 0V, just like it's supposed to. So basically I have everything set up the way I had it in the first place when it worked, and it seems to be working fine. However I'm a little leary about it considering it quit working before, while I had it wired the same way, and the funny continuity test on the cable from the heater to the thermostat also worries me. So I'm going to leave it hooked up with the wires and everything exposed for a while and continue checking it.
But what the heck is going on with it? I don't want to mount everything back together and then later have the homeowner call me telling me it's not working. If I run into any more problems, I'm thinking the only thing I can do is forget that old wire going from the thermostat to the heater all together, and run a new cable for it, but if I do that, it will have to be in a different location which won't be very convenient.
1 - 8 of 8 Posts
Ok, I got about a sentence in and went partially blind, then my eyes started to bleed.
For my sake, and others, use the return button to create paragraphs....
Then and only then will you find the answer to your problem.
I did the same as Mark- it is confusing---- But I believe that you had a bad connection at first-perhaps a wire nut- hence the funny readings-& when you re-hooked it up- you fixed the Problem...............
I looked at this last night around midnight and i couldnt keep the eyes focused long enough to read the whole thing. I also agree that you had a loose connection. Are you twisting the wires properly and using good quality wire nuts?
thermo
yep...connections....maybe thermostat is going bad. They do that once in a while. Think they are only $10 or so to replace.
Forgot to mention, I replaced the old thermostat with a new one too.
That was my first though, a loose connection. But I took it apart, twisted the crap out of the wires, put tape around it, then a wire nut. Put it all together and it still didn't work. After that, I unmounted the heater, hooked it up with all the wiring exposed so I could test it to see what was wrong, and then everything worked. That's why I was getting confused, I put it all back together and it seems to be working fine. Maybe it was a combination of things going wrong, maybe I spaced out and wired something wrong during my failed tests, I don't see how that's possible though.
I never thought about the quality of the wire nuts. I used the kind at Home Depot that come in a large plastic container with half red and half yellow ones, they seemed like they were decent enough.
heater
Most likely you fixed it, but you did so many things that you'll never really know which thing you did that fixed it. It will drive you crazy for years not knowing what it was. I've had a bunch where I just started correcting things and not rechecking after each thing so really never know I did to fix. If they cranked it for a few days and no call, your probably ok.....don't let the mystery haunt you
Yeah you're right, I'll relax.
1 - 8 of 8 Posts
