1 - 2 of 2 Posts
Property Preservation
Power Inverter - 3000w 25.5a - Vector Maxx SST - $200.00
This unit was purchased new and was only used for a little more than 1 year.
I needed to upgrade to a portable generator.
I will also include the 4 power cables with alligator clips to attach to your battery.
This inverter was first used for a car stereo system then for various power tools, vacuum and air compressor.
This unit runs most AC powered electronic equipment, including TV/VCR combination, Refrigerators and Microwave Ovens, Stereo Systems, Computers, Household Appliances, Power Tools, Wet/Dry Vacuums, Small Pumps, Motors and more.
* 3000 watts continuous power
* 6000 watts surge capacity (peak power)
* Four AC receptacles
* Features high surge capability to start heavy loads such as lamps, motors & other inductive loads
* Powerful internal high-speed cooling fan
* High voltage protection
* Low voltage protection
* Overload protection
* Low battery alarm
* Low battery shutdown
* Short circuit protection
* Remote switch capable
Maximum efficiency Approximately 90%
No-load draw < 1.0 amp
Output Wave Form Modified Sinewave
Input voltage range 10 - 15 VDC
Output voltage range 110/120 VAC 60 HZ
Low voltage alarm 10.5 volts
Low voltage shutdown 10.0 volts auto reset
Thermal shutdown Yes, auto reset
Inverter weight 11 lbs
Product dimensions 11.5"x 9 "x 5 "
Please call: Rob @ (440) 478-1155
I am asking $200.00. and can ship anywhere
I accept paypal and personal checks.
1 - 2 of 2 Posts
