Status
Not open for further replies.
901K views 4.3K replies 507 participants last post by  Leo G
Since probably every contractor has a digital camera, I think it would be interesting if we pick Friday, for instance, and everyone (even the plumbers) take a picture of what you are doing, or project, and post them on Saturday or Sunday. My camera is in my truck with 2 months worth of pictures on it....and I need to download and sort anyway.
So how about it? Let's all post a picture by this weekend of a project.
#2,153 ·
Gene,
The table that you are creating is unique - I've never seen this combination of Black Walnut with Concrete using dovetails. I'm sure it will be spectacular after you've had the chance to polish and seal.
I noticed some concern in one of the posts above about the small amount of concrete shinkage that will probably occur as the concrete ages, however I would be more concerned with wood movement due to our significant changes in humidity (summer to winter), and the effect of this constant cycling. Did you provide some flex between the tails and the concrete pins or do you think that locking the walnut and concrete to the plywood base will reduce the effect of humidity changes on the wood?
Perhaps you have seen such an arrangement before, in which case I shouldn't be so paranoid. Good luck with it, and if it works with no problem, you've created something new that I'd like to try it also.
#2,154 ·
Gene,
Movement is always a concern, whenever different materials are joined. All of the measures i have taken, as you mentioned, hopefully will compensate for the movement, the walnut has been Kiln dried, and the concrete is drying slowly, i will keep this forum informed of the tables future. G
#2,160 ·
Nope. Even the brick at the gables was ok except the front gable which I think was damaged by the fire dept. We are building new wood gable walls which will be moved out flush to the brick, and then vinyl sided. This house was probably worth 70k before the fire. I can't believe they didn't just demo the whole thing. All exterior walls are 4 inch block with brick veneer, then 3/4 furring, with no insulation. Building dept is making contractor furr all exterior walls to achieve an r 13 value. Looks like the fire probably started in living room(wall heater?) and burned through about a dozen joists, then straight up and through the roof at the front gable. This is our first major fire job. Maybe our last, as this work sucks! I bid this job back in May when things were slow, but now we are acrambling around trying to man 4 jobs with 8-10 guys.
#2,159 ·
Hi Gene,
You are on the cutting edge.
I was thinking a little more about this possible problem - it would be a shame to have checks show up in the beautiful walnut tails. I hear you about kiln dried, but regardless, the walnut will absorb moisture from the atmosphere and correspondingly loose it during the dry winter months. There is no question that the walnut will shrink and grow as a result. You may be able to reduce this continuous dimensional change by coating all surfaces of the walnut with a water proof seal, such as epoxy. You could use West System epoxy (does not smell) which would prevent moisture entering the wood. If you don't like a shiny surface, steel wool or bronze wool it with extra fine wool.
Anyway, I hope I'm not making a problem when none exists.
Richard
#2,163 ·
Recent job was at a synagogue in downtown StL. The 20+ yr old acoustical fabric was shot, and failing all over the place. We had to strip it all, vaccuum-sand the walls, and primed with Gardz. Then installed new fabric. It sucked big time trying to overlap and double-cut a thick, felt-like fabric over plaster walls. The plaster ate my razorblades, I used probably 20 blades per seam. My finger tip is raw.
#2,174 · (Edited)
Looks like my set up.
How long is that alum. plank?
I've been using the 32' and she's a b*tch to move around,but better than a third pole.
I'm not a real big fan of the verticle siding,but it seems to fit that style house.
How'd you trim those windows?
Looks like j from a distance.
#2,177 ·
Before & After
This was a combo tile & fiberglass shower that was framed small to support small enclosure. We added an extra 9 inches to lengh .We used the leftover tile to a little character to the tub surround.
At the last minute they also had me also do the floors.
Status
You have insufficient privileges to reply here.
