796K views 12K replies 233 participants last post by  tjbnwi
Previous Threads.
Part I
Part II
#1,084 ·
Got a few more layers done on the entryway. Goes slow when you have to make your own moldings.
Added a 7/8" x 3 1/2" sub layer, then a 3/4" x 3/4" quarter round under the sub layer. After that I made a 1" x 3 1/2" dentil with 1 1/4" teeth and a 1 1/8" space. Sanding and breaking edges takes a while. That got placed on top of the sub layer.
Then the bottom of the shadow box was made from a 3/4" x 6 1/8" board mitered an has 4 1/2" showing. It'll lose 1/4" when the face of the shadow box is attached using a dado.
Then a small molding wrapped around the dentil to transition to the shadow box.
Next will be the shadow box and the roof. Then I'll work on fluting the pilasters and the plinth blocks. After that the various moldings that go on the plinth and pilasters.
#1,086 ·
Started on Tuesday, but I've been bouncing around between some other smaller projects.
#1,089 ·
Man the day flew by. Had to make some cherry cabinet stuff for someone else and I had the stain all mixed and ready to go. Did a test pc and the stain was not even close. So had to take a trip to Atlantic Plywood to have a custom stain made and it won't be ready until Monday. So all that cherry work was for nothing.
Glued up the stock for the plinth blocks, made the molding that goes on top of the plinth, made one of the three moldings that go on top of the pilaster.
Made the shadow box and crown and got them installed.
PITA crown. 35Âş-55Âş spring angle. Had to mill the bottom angle standing up against the fence.
#1,090 ·
Decided to build a shed for a family friend. Was a bit more time and money than I generously offered. Priming end cuts and metal flashing takes time.
I figured a week and that was Thursday. Still have fascia to wrap and corner posts. Rushing to get done I can cut a piece short. :sad:
#1,098 ·
Still have to put the top (roof) on above the crown but that's not going to change the look. ALso need to make the sill board that goes under the threshold to support it. That continues underneath the plinth blocks to support the shorter retunrn.
Not sure if I'll use copper or lead flashing. Lead would be more period correct but copper will end up with that blue-green patina that people like. Plus it's not as expensive. I can bend the lead without a brake, the copper - not so much.
#1,101 ·
Made the top (roof) today. Cheated. Used Poplar instead of the Red Grandis. I'll be epoxying it and it'll be under copper or lead flashing.
#1,110 ·
Capillary action will defy gravity.
#1,109 ·
Starting up on the hood which will be my last project for a while for this client. I took my measurements and did my CAD drawing, figured out the curves in the CAD and made my curved sections. I made 6 of them, 2 for each side. I'll have to do the corners in the shop because they are a different shape because they'll be at a 45Âş angle.
So instead of hoping I got it right I did some of the frame at the house. I was there for other reasons so I figured why not just do this there and make my life easy and not have to worry if it'll fit or not.
Here's the look she wants and the CAD drawing.
And then I took it off the wall, disassembled most of it because it's been pouring rain and I don't have a covered vehicle and brought it to the shop.
At the shop I started putting it back together, this time with glue. Figured out how the right front and side curved elements would join together and clamped them in place. Then I had the measurements for the left and just put them in place. That's where I am in the process right now. I'll likely make one more curved part for the front center and then connect them at the top.
#1,114 ·
Got a 36" range hood similar design, but all wood, que'd up for mid next week. So I'm curious, you going to have a 'hip' element or just form those corners with the metal?
#1,118 ·
Yes it'll have the hip curve. I'll stick square stock in there with the appropriate compound angles and use a stick with a pencil to trace the pattern using the other curves as a guide.
Not sure if I'll use two 3/4" pcs so I have a good wide nailing surface or just 1 one 3/4". The top surface will have a point beveled at 90Âş so the "roof" lays flat on the hip.
Should take a good while to figure it out.
That's a fact. I'm going a slightly different route on figuring the hip rib out. Just me and certainly not pushing this as the best or most efficient way ... Cad and template for the whole nut. Thinking at best it's a wash on time to do the additional cad vs tracing and cutting. Me, having an accurate starting point, less worries overall. Still does not eliminate the hard part. Transitioning angles on the hip rib edge. Thats all hand grinding and sanding.
Got a sheet of 1/4 bendy ply sitting around (need to burn that up), so extra ribs. Plus it's just getting veneered, with that ugly alder :laughing:, a bit more support is in order I believe.
