3 reading
801K views 12K replies 233 participants last post by  tjbnwi
Previous Threads.
Part I
Part II
#9,548 ·
Got 6 stained doors. 4 had panels and 2 had glass. They wanted the reverse. Made a jig for a router with a pattern bearing on it and cut out the inside backer that held in the panels, got some glass made with a cathedral top and installed it with quarter round I made, stained and finished.
Before:
After:
And then there were the 2 glass doors with mullions that needed the glass removed and the mullions eliminated. The quarter round was installed with 21ga staples, those were fun. Quarter round broke at every staple and then there was the hot melt glue they put in there to make it a real joy to remove them. The mullions were also hot melt glued in. Found that out after slightly damaging the bead under one of the mullions (sanded it out). After that I set the heat gun at 300F and was able to remove them without damaging the other part of the door.
Before:
After:
The finish is still a little glossier than the frames because it's fresh. It'll take a week or so before it gets to it actual sheen. Hopefully it'll match well. Color is very close, not perfect. They used a two step system and I tried with my stain to do the same but the toner I used made the color to bright. So I just said f it, good enough.
Pin will tell you how hard it is to get a perfect match.
#9,550 ·
Framing is going slow but it's hot, I figured the framing for spring but looks like we will make out ok. Put an extra helper and a guy whose almost allowed to call himself a carpenter out there to help rotate guys to break in the afternoons. It's a bad bish on that slab after 2 o'clock, heats magnified big time on a slab
Garage is to the right of the white van, can't get it all in one pic, need to get a drone
#9,554 ·
Framing is going slow but it's hot, I figured the framing for spring but looks like we will make out ok. Put an extra helper and a guy whose almost allowed to call himself a carpenter out there to help rotate guys to break in the afternoons. It's a bad bish on that slab after 2 o'clock, heats magnified big time on a slab View attachment 553679
Wow not even big enough to put my shoes on in the morning without my butt hanging out the back window, you should put wheels on it and Call it a camper😂
J/k
Nice
#9,556 ·
Knotty Oaks, a custom we are building in Castell. Superintendent gets back from vacation Monday, we have final walk through scheduled before we vacuum out the stud cavities and get the MEP inspection and spray foam.
They are killing me on the windows, it's going to end up sitting because the designer and client went months past their deadline on the Selections Priority Calander. She's OK with it so thats good, just not great for cash flow lol
#9,558 ·
Over 16" of rain in July. Looks great Sno. (y)
#9,561 ·
Needs sanding. Maybe a mahogany stain to bring out the details.
#9,565 ·
Time for cups an injectors?
Sent from my SM-G998U using Tapatalk
#4 injector was leaking, enough fuel leaked out where it hydraulic locked the engine after it was shut off. Good thing is the piston was at TDC and the starter couldn’t turn through the lock, nothing got bent. I think the issue started about 6 weeks ago, a couple of mornings it just cranked weird, then no issues at all until the lock.
Cups just because I have it apart, no signs of fuel in the coolant.
Damn things only last 405K miles.
I’m changing the HPOP right away, didn’t plan on changing the IPR but I can’t get it out of the old pump after being in the pump for the last 23 years.
Tom
#9,570 ·
Finally finished with the touchups, the client had a request about the left side when he’s on the porch in the evening, the lights coming around the corner from the cars are blinding him, but code does not allow us to install windows or screens, he’s not interested in large, ugly shrubs Any suggestions ? I could install a trellis and then plant some Ivy’s below?
