Can't tell if the inside part is capped off with a plate... may want to foam inside as well to keep condensation from rusting from the inside out?Happy with how its looking and coming out.
I am concerned with the steel sweating inside the home. I'll be spray foaming the interior of the joist at the rim of home. I'll also likely encapsulate the inner 8' of the joists with foam to reduce heat loss and condensation.![]()
Just box steel with a side weld. I'll foam the interior of the steel joist in the rim area above the wall, seal off airflow from the exterior. Then I'll cap the interior end and holes. I am thinking it best to not allow future air into the interior of the joist.Can't tell if the inside part is capped off with a plate... may want to foam inside as well to keep condensation from rusting from the inside out?
Your install work (and I’m no true framer by any stretch) and personal pride in your work is contagious man. I have really been inspired and re energized seeing your jobsite posts. It’s guys like you who give two f##ks after the check clears that keeps me cognitive of making the right decision getting into this game. Respect dude.Happy with how its looking and coming out.
Not really, our soil can be very expansive (we call it black gumbo). Our typical pier is a 12" shaft with a 36" bell bottom. Of course we do what the engineers specify, so we follow their design.Allan,
Have you looked into helical piers in lieu of all the concrete?
Tom
There's really no direct comparison for lumens when going from HPS to a 5000K LED. I've swapped out 400 watt HPS with 125 watt LED and it's a billion times brighter.They just did that on one of the buildings in the parking lot where my shop is. We will evaluate them on that building and when they put them on the building I occupy they may be the same or upgraded to a higher wattage depending on what they think of the new ones.
I have no specifics but I'll bet they put up 50 watters to replace the 250 watt sodium lights. The lumen number comparison isn't even close 26K vs 7K for the LED. But the color difference might make up for it. I think a 75 watt LED is more comparable.
